orjan.almen
- Mark as Read
- Printer Friendly Page
06-07-22
05:22 PM
Status:
New
Right now, When adding DLLs to an object, you can either set your relative path to the dll and it will look for the file in the Blue Prism install folder, or you can specify a full path to a file.
I would find it useful to be able to set a path in the database as a second place for Blue Prism to find these dlls and not require to place dlls directly into Blue Prism install directory. This will help keeping blue Prism install directory clean and easy to manage over time. Also it will not require enterprise environments to repackage and update a new version of Blue Prism to be sent out for every dll to be added for object usage..
