Asilarow
Currently Blue Prism can only be deployed on an MS SQL Server instances, and the recommended version is Enterprise which comes at quite a high price tag, making it expensive for smaller deployments, and/or smaller companies wanting to use Blue Prism.
As the times are changing and a lot of non-enterprise companies are looking to streamline their operations and automate their processes, a high deployment cost (and maintenance) for infrastructure is often viewed as a blocker.
This being said... can you please add support for PostgreSQL as well as MySQL databases for the Blue Prism DB Server?
3 Comments
DexterWhelan
valid point, would like to see this improvement. would be a nice step in a direction sorely needed.
jhogelp
Level 8
You are idea is very good to consider
AmyTsaousi
Community Team
Community Team
Hi Andrzej,
Thanks for submitting your idea, the team really like it and think it will be a very useful feature. I’ve updated the status to Under Consideration and you will see updates here as it progresses through the process.
Best Regards,
Amy
