Stefan__Pappalardo
Level 7
- Mark as Read
- Printer Friendly Page
27-08-21
09:06 AM
Status:
Not Planned
The count of components depending on Message Broker RabbitMQ is growing. At the time of writing I know of the following components.
Please consider to add documentation that can give answers to the following questions.
- Blue Prism Hub/Interact
- Blue Prism Decipher IDP
- Is it recommended or even viable to share one RabbitMQ server instance in a BPA environment with Decipher and Hub/Interact?
(Currently the installation guide only describes from the perspective of the component, not seeing the big picture.) - Does RabbitMQ offer Active Directory Intergration with SSO (without providing username and password, direct passthrough)?
- Is it really needed to use RMQ management plugin to operate a RabbitMQ server instance?
- Which operating system (Windows or Linux) is best to be chosen for RabbitMQ?
- Are there any restrictions when preferring Windows over Linux?
- What about Authentication and Authorization?
- Is it recommended or even viable to use a technical service domain user account, and if yes how?
- Can/should guest user (default Admin account !) be deactivated before installation, and if yes how?
- What about encryption?
- Is encryption needed, recommended, and if yes which is supported and how does it interoperate with the Blue Prism components?
- Is there professional support available, and if yes will it be provided by Blue Prism or someone else?
1 Comment
