jgregor4
Status: New
It would be preferable to have an additional setting with regards to logging and sensitive data. While logging can be disabled or set to not log the parameters, if such instance occurs where full logging has to be enabled at resource level to determine an issue - it would be ideal to have been able to set a level of logging that still would not be captured in the logs.
We have many processes that deal with sensitive data and have to build numerous work arounds to get the data in a way that would not accidently be exposed in the logs.
If there was a setting similar to not log parameters it would allow us to build "normally" knowing that if full logging needed to be enabled, this data would be safe from the logs.
