DanielGabriel
Status: Not Planned
The application binary was compiled without enabling Control Flow Guard (CFG, a security feature that helps prevent memory corruption attacks such as indirect call/jump hijacking. This omission increases the risk of exploitation through techniques like Return-Oriented Programming (ROP).
It is recommended to set Control Flow Guard value "true".
2 Comments
DanielGabriel
Status changed to: Not Planned
Hello Daniel,
Thanks for taking the time to raise an idea. Having consulted with our engineering team, I can confirm that we will not be taking this enhancement forward.
The application binary (automate.exe) is a .NET Framework application. Control Flow Guard (CFG) is a Windows security mitigation designed for native (C/C++) binaries - it is not appropriate to enable on managed .NET Framework applications, where it would cause stability issues without providing a meaningful security benefit. The .NET runtime already protects against the class of memory-corruption attacks that CFG is designed to mitigate.
If this request was prompted by a security scanner flagging the binary, this is a known false positive for managed .NET applications.
As a result of this update, I'm going to mark this idea as Not Planned.
Rob
