The application binary was compiled without enabling Control Flow Guard (CFG, a security feature that helps prevent memory corruption attacks such as indirect call/jump hijacking. This omission increases the risk of exploitation through techniques like Return-Oriented Programming (ROP).
It is recommended to set Control Flow Guard value "true".
