StephenAldred
Status: Delivered
Hi, just seen on BPW21 a demo from ABBYY where Timeline PI can integrate with Capture to populate the process flow from Timeline on to Capture. I understand this is limited to ABBYY and no plans to add other process mining platforms, but this looked really great and Blue Prism will be missing a trick to limit this to only customers with Timeline. Can you consider adding other process mining tools, like Celonis which my company use.
3 Comments
MelanieGiuliani
Community Team Alumni
Hi Stephen,
Thank you for your idea! Our internal team has reviewed it, and has determined that we need a bit more information before we're able to make a decision on how to advance your idea along the lifecycle.
Can you provide a bit more info on what specifically you'd like to see in terms of integration?
Thank you!
Melanie
Amy_T
Community Team
Community Team
Hi Stephen,
We've reviewed your idea again and have decided to move your idea along the ideas process to under consideration while we route the idea through our internal review process.
Thank you!
Amy
Status changed to: Delivered
Otto_Mation
This idea has been updated by the SS&C Blue Prism Product Management Team
