kentarootaki
Status: Needs More Info
I divide up posted idea about visually impaired engineers.
I want to bring up the idea of Blue Prism's UI in this post.
I hope that the UI of Blue Prism can perform all operations with shortcut keys.
The visually impaired engineer will more actively participate in developing if it comes true.
1 Comment
Amy_T
Community Team
Community Team
Hi Kentaro,
Thank you for splitting your two ideas into separate suggestions. Can you help us understand the context / problem you're facing to suggest having short keys for all Blue Prism UI?
Also, where you have said to have short keys for all Blue Prism UI, can you please confirm is this suggestion specifically for Control room, Design studio, etc.?
Many thanks,
Amy
