Description
The column order in the Sessions view has changed. Previously, the Digital Worker column was positioned closer to the beginning of the grid. It now appears that the Digital Worker and Failure Reason columns have changed positions.
This change makes it more difficult for administrators and support teams to quickly identify on which Digital Worker a process is running or has failed. As a result, monitoring and troubleshooting robot processes has become less efficient.
Requested Change
Be able to change the column order so that the Digital Worker column for instance is displayed before the Failure Reason column.
Business Impact
Current Behavior
Expected Behavior
Acceptance Criteria
Priority
Medium (Usability / Operational Efficiency)
Justification
A recent change in the column order has reduced the usability of the Sessions view for operational support and monitoring activities. Changing the column order to place Digital Worker before Failure Reason will improve visibility and help users identify the affected Digital Worker more quickly when reviewing active or failed sessions.
