doran.george
Status: Not Planned
Manage Connection Issue:
Importing a json file through managed connections, re-importing due to a change in json file does not let you override the existing naming , making copy(1) of the connection name. any thoughts/enhancements to address this?
2 Comments
doran.george
I am withdrawing this idea.  The process works well enough.  If you submit an updated json file, the naming can be the same with an addition character; like 'v2; or whatever.  After import, rename back to your original name, since the service calls will have the same name.
Status changed to: Not Planned
ustevens
