jmcastan
Status: Needs More Info
Today, designers can create and save Process Flow and Automation Service assets, but Chorus lacks a curated, searchable library with categories. This makes existing components hard to find and often leads to re‑building existing work.
I propose a Reusable Library embedded in Design Studio where PF and AS assets are categorized and searchable by name or category. This would allow entries to become discoverable via a search by category/name when creating a new Service element. From the designer’s perspective, a one‑click Insert would drop the selected asset directly into a Process Flow or an Automation Service canvas.
This would reduce duplicate work, improve design speed, and ensure consistency across builds.
3 Comments
HaleyHuffman
Great Idea! This would make it alot easier to find things!
Clararaj
I understand the requirement of categorizing Presentation Flows and Automation Services - so that you can easily search or navigate to them.
You also mentioned - 'From the designer’s perspective, a one‑click Insert would drop the selected asset directly into a Process Flow or an Automation Service canvas.'
Is this when you are configuring the User Task / Service Task in a Process model ?
jmcastan
Yes, after placing a Task and choosing a "Service Task" an additional option of category would be useful to help identify which AS/PF could be used.
