PawełImiołek
Status: Reviewed
Access to session log is not an obvious facility in Blue Prism Control Room. From time to time it may happen that due to performance issue and reaching timeout session log does not get displayed at all. In this situation, if we want to find out what were exactly the input parameters thanks to which we can differentiate one run of the same process from another, we either lose this detail or guess it with a higher or lower confidence, for instance by relying on the time of run.
To achieve more readability of in/out parameters, it would be beneficial if users had an opportunity to have them displayed while hovering their mouse over a particular run of process in the Control Room instead of counting on session log being correctly opened and reading parameters from it.
Best regards,
Paweł
2 Comments
KrzysztofWalkow
Level 1
I think, it is worth considering to have similar information while checking Items in queue. For example when item was marked as exception it would be great to check what data were used while the action thrown an error and maybe even more, for the data stored in the Item Data. In case of sensitive data these data should not be displayed.
chris.strong
Hello Pawel,
Thank you for raising this request, this makes sense and I can see how this is useful when you change the flow through a process based on the start property data you set.
Changing status to Reviewed.
Thank you
Chris Strong
Blue Prism Product Manager
