In Blue Prism Decipher IDP v1.2 you need to turn on every process module in the workflow configuration to be able to modify all related role settings. If a process module is turned off the related role is not available for setting. Already set roles are visible, but can not be changed.
This behavior is unexpected and adds no value to the product. But it makes usual sysadmins work more complicated and adds additional effort to your customers, like investigating this confusing behavior and switching on/off process modules in workflow configuration to be able to adjust roles in user and user group settings. And on top of all, two process modules (Classification, Class verify) are turned off by default for no obvious reason.
Please decouple user and user group settings from the process module settings in the workflow configuration. Every available role need to be editable in the user and user group settings independently from the activation state of process modules.
