AvinashRamkumar
Status: New
Blue Prism helps in automating lot of manual work. However the process of doing release/deployment is time consuming. For a bigger RPA CoEs, it would be really helpful if deployments could be done using AutomateC/CommandLine with option to select components from a release file rather than having to import everything by default.
