ChrisBrook
Status: Delivered
Problem Statement:
Currently we have a number of use cases which require Python scripts to complete specific NLE activity or to support with the management of files such as:
  • encrypting/ decrypting with specific PGP keys
  • converting protected PDF documents to unprotected, editable and readable documents for OCR extraction
  • managing multiple PDF documents such as deleting pages, merging documents
These scripts are currently utilised as standalone py files which are triggered via Blue Prism; but not within Blue Prism.
Proposed Solution:
  • Include Python as a supported language within Blue Prism code stages
  • Provide Python as an installable supporting application alongside core Blue Prism product installer
  • Provide the ability to run 'pip install' to obtain dependencies for scripts all within Blue Prism.
23 Comments
This Feature will help us a lot
BohyonHwang
Level 9
should be really amazing
EslamGhandour
This is already available and you can do it by adding the ironpython.dll file to be available for your object studio.
Refer to Code Stage document page 30
https://community.blueprism.com/HigherLogic/System/DownloadDocumentFile.ashx?DocumentFileKey=c0683b90-4d0c-4c52-b20e-098a2eab426d
I do agree that it's considered a bit complicated and it can be simplified, but you still can utilize it.
c202c0y
@EslamGhandour Thanks for the link. How and where did you find this document?
EslamGhandour
@c202c0y
Usually when I face an issue I always search the community for situations like it. You can refer to this post where I found the document provided by one of the community moderator.
https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=385&MessageKey=2b0da48e-fa4f-4c7b-82e8-4d28d1d8b725&CommunityKey=1e516cfe-4d1f-4de9-a9eb-58d15bf38c81
c202c0y
@EslamGhandour Thanks. I just wanted to understand where they have documents like that. I couldn’t find it on BP docs or anywhere else, so I wondered where they had placed it. It's a bit unfortunate when useful documents like this just are in community threads..
Amy_T
Community Team
Community Team
Hi Chris,
Thank you for submitting your idea. We've reviewed it and has been submitted to be scored by the rest of our ideation team.
Please check back for progress on your idea in the future.
Many thanks,
Amy
Jatin__Kalra
Hi Team, We should add a stage in Process studio or in Object Studio where developers can execute python, vba and all other scripts. This same functionality is already available in all other automation tool.
Jatin__Kalra
I know about the functionality which is mentioned in https://community.blueprism.com/HigherLogic/System/DownloadDocumentFile.ashx?DocumentFileKey=c0683b90-4d0c-4c52-b20e-098a2eab426d
but we can make the steps more easier as this lot of time and efforts there should be direct stage where you copy and paste all code and directly execute it.
PvD_SE
Level 12
This idea should be implemented in either the Code stage that we have today, or in a new Python Code stage. This has been asked for several times before, please implement.
