damian.nowicki
Status: New
While configuring a Flow in WorkHQ's Automation Orchestrator it is possible to use process chain feature that makes sure that the execution of each process step happens in a defined order. However, the current limitation of maximum 3 processes in a chain makes the feature not applicable for more complex flow setups.
I'd appreciate this idea to be reviewed in order to check if it's feasible to increase the maximum number of processes that can be configured in a chain.
Thank you.
