rlarson
Status: New
In blue prism, while in control room, it would be great to be able to filter available processes when trying to manually drag and drop one onto an available resource. You can currently filter by resource, but not process, so you are always left scrolling to find what you need.
1 Comment
naveed_raza
Level 7
Yes, it would be good if we get this feature , as i have around 50+ automations which is running LIVE, most of the time i have to scroll up and down to go that process to run manually on available resource.
Team, can you please add this feature same like how we have in Studio page to filter out the processes and also for resource sections.
this will help alot and makes our job easy.
#Filter , #Search, #Control Room
