Status: New
If you're using Blue Prism Hub you must have come across this error.
Rather than having a static message for any error "Something went wrong" is definitely a bad idea.
All the apps have their logs Hub should have the ability to read the log and display the actual error on screen so the user can understand the issue.
Right now troubleshooting the Hub, Interact, BPD, and Auth Server is a cumbersome task.
1 Comment
EmersonF
I agree with that, every time I came across this, it always took me longer than necessary to find and fix the problem
