HarshitRawat
Level 8
Status: New
Some small enhancements would make Bluerism more user friendly.
Right now when a session is in progress, unless you yourself developed the process, there is no way for someone to know if Safe stop is implemented in the flow. If it is not implemented , and you select Request stop , the session would just continue showing Stopping.
I suggest having a small visual indicator to indicate if a process has it implemented in place
