Problem statement:
if there is a change in the application layout as part of an upgrade the RPA process which was built on the previous version will fail. Now it takes a lot of effort to identify the changes happened to the elements that are identified previously..
idea:
Application modeler should have a built in functionality to compare previously captured element and new element and highlight the differences option to Calibrate the previous version of elements with introduced changes.
