StephenAldred
- Mark as Read
- Printer Friendly Page
20-05-21
01:42 PM
Status:
Under Consideration
Hi, just seen on BPW21 a demo from ABBYY where Timeline PI can integrate with Capture to populate the process flow from Timeline on to Capture. I understand this is limited to ABBYY and no plans to add other process mining platforms, but this looked really great and Blue Prism will be missing a trick to limit this to only customers with Timeline. Can you consider adding other process mining tools, like Celonis which my company use.
2 Comments
