GopalBhaire
Level 10
Status: Delivered
Currently finding the documents in the portal is a bit tedious, we can search document based on the name but most of the time it returns either a list of unrelated docs or no docs.
For e.g. searching for 'browser' returns no result but we have docs with name like Chrome Integration, etc which is related to browser.
If possible, please make the document searchable from the search bar itself so that find the document is quick and easy.
2 Comments
MelanieGiuliani
Community Team (Retired)
Hi Gopal,
Thanks so much for your feedback! Search is something we are currently looking into expanding and improving, and your feedback on finding documents is something we'll consider carefully as we move forward with this project.
We will keep you updated as we progress.
Thank you,
Melanie
Status changed to: Delivered
Hi @GopalBhaire,
In the past few years, we've been iteratively updating the functions that search our documentation to better integrate all of our related platforms (BP Docs, Blue Prism University, the Digital Exchange, the Community, etc.) and to drive this to use more semantic searching, which is addressing the idea that you raised some time ago.
As a result of this update, I'm marking this idea as Delivered.
Rob
