GopalBhaire
Level 10
Currently finding the documents in the portal is a bit tedious, we can search document based on the name but most of the time it returns either a list of unrelated docs or no docs.
For e.g. searching for 'browser' returns no result but we have docs with name like Chrome Integration, etc which is related to browser.
If possible, please make the document searchable from the search bar itself so that find the document is quick and easy.
1 Comment
MelanieGiuliani
Community Team (Retired)
Hi Gopal,
Thanks so much for your feedback! Search is something we are currently looking into expanding and improving, and your feedback on finding documents is something we'll consider carefully as we move forward with this project.
We will keep you updated as we progress.
Thank you,
Melanie
