- Mark as Read
- Printer Friendly Page
Hi BP Team,
The ability to select and mark multiple queue items as exception. Not having this option was a bit of a surprise. What happens if you need to mark a huge volume of items? I had to already and it took long. The data provided to the queue was bad so I could not retry and didn't have much of an option.
There should be an option to make changes to multiple items on a page regardless of the status.
Having to do one at a time when you have a large volume items isn't practical.
The items also can't remain in a pending state because then the DW will pick them up.
Along with that, an option to empty a work queue would also be nice. Having to then select all delete multiple pages of data, if ever needed, can also be unnecessarily tedious.
Thank you,
