The option to pin data items so their values remain on screen while the process runs would be great. Maybe a ribbon somewhere could contain these so they're always visible. Having to pause a process then potentially change pages and or scroll to find the current value of a data item is wasted time.
The ribbon could be able to be pinned so it could be closed when not needed.
