- Mark as Read
- Printer Friendly Page
When sharing the BP database within a large company, the number of processes and objects and the group folder they're save on might grow very long. Finding the process or object you're working on might require a number of clicks.
This behavior is not helped by the fact that the Studio panel groups are collapsed again every time you visited another panel such as the Control Room.
1. Don't collapse groups in Studio once opened, leave them expanded even when returning to Studio when other panels are visited.
2. Create the possibility to mark my projects so I can find them easily by a single click. See MS Visual Studio or open source Eclipse how it is done there.
I reckon both these options would be nice to have in Control Room also...
