AlexanderFische
Web API and Skills are offering an easy and fast way to use external Webservices.
Unfortunately this is not possible if you need a proxy authentication and therefore you'll get message like
Internal : Unexpected error Error during Web API HTTP Request
HTTP Status Code: 407
HTTP Response Content: <HTML><HEAD>
<TITLE>Access Denied</TITLE>
There is a workaround of using HTTP and REST VBOs instead of Web API, which will allow to set Proxy for a request, but this means that you can't use Web API and Skills here. This will a mean lot of more efforts in implementation of many use cases.
So in our opinion it would be a very good feature to have such an option also für Web API and within Skills.
3 Comments
matt.digby
Level 1
Just came across this. This would be very helpful, I imagine a lot of Blue Prism customers (medium/large/enterprise business) would have an internet proxy, most likely authenticated so it seems like it would be a fairly common need.
Hope this can be implemented soon!
Amy_T
Community Team
Community Team
Hi Alexander,
Thank you for your idea. I've updated the status to Under Consideration and you will see updates here as it progresses through the process.
Best Regards,
Amy
Status changed to: Under Consideration
Otto_Mation
This idea has been updated by the SS&C Blue Prism Product Management Team
