RameshSambari
- Mark as Read
- Printer Friendly Page
09-07-21
06:25 PM
Status:
New
Hi Team,
As you are aware that MaxUndoLevels in Automate.config file plays a key role in Blue prism Memory Management. Now we are setting this value by searching that word in config file and replace value with required count. Instead, it would be great if there is a command line option to set this, using, AutomateC.exe.
Thanks & Regards
Ramesh Sambari
Thanks & Regards
Ramesh Sambari
