amitdange15
Status: Delivered
Empower Your Design Precision with UX Builder Sections: Unlock Vertical Section Management!
Gain full control over the height and length adjustments, ensuring seamless vertical arrangement of content. No more limitations – optimize the display of text, labels, and various content types for an impeccable user experience.
Take charge of your design and make your content look exactly as intended.
Currently UXB Headers -
Expected Header-
If required users should be able to like labels -
2 Comments
Clararaj
With UX Builder V17 - we did release the Compact theme that has far less spaces compared to the default theme.
However I think there is still a need to look at how we can control spacing and padding for our controls.
Status changed to: Delivered
Clararaj
This capability is partially delivered - you can adjust the width of the columns and also add new columns if needed.
We have a backlog item - where in better and efficient ways of managing spaces and padding of elements will ve explored.
