A Quality of Life suggestion. Take, for example, the humble 'Item Data' collection, after getting an item from the queue. There could be any number of fields in this collection that will be referred to constantly throughout the rest of the process. Each time you need to refer to one of them, you have to type [Item Data.Field Name], being very careful with your typing. It would be much simpler to instead co-opt the fields that are returned from the queue and have them going forward as pre-defined fields that you can click on via the expression editor.
