In work HQ Workflow Studio - > I created a connection using the M365 Excel Connector and provided the Client ID, Client Secret, Tenant ID, and URL. The connection was created successfully and is currently shown in yellow status in my snapshot.
Now, I need to update only one of the values that I previously entered. However, I cannot find an option to edit the existing connection. The only option available is Reconnect, which prompts me to enter all the connection details again.
Is there a way to modify a single connection parameter without recreating or re-entering all the values?
