| Ability to code users for primary queue. Work can be same Unitcd/worktype but across multiple queues. IF user coded for: Unitcd = fundco Worktype = purchase Queue = processing and quality Currently user would then get the work based on FIFO or priorities. But there should be a way to get and finish all the work in the Processing queue first and then Quality. Without having to code and recode at user or role level |
