Citrix application issue
pranavbaraskar
Hi
I am trying to automate a citrix application which is launched through a web based application. Steps are as below
1. Log into a website (IE)
2. navigate to a particular icon and click it
3. the citrix application is lauched which will prompt for its login window
when i do these steps manually the citrix application will lauch but when i have BOT do these steps i can see bot doing the setp 1 & 2 but the application wont start
Anyone can help with this. I can share my screen.
thank you
Pranav
pranav baraskar
5 REPLIES 5
SidramappaHunas
Hi
Can we connect tomorrow we can check it once.
Sidramappa Hunashyal
SA
Accenture
absolutely, what time? here's my number +17163619903 I am in EST
pranav baraskar
sure let me what time i am in est.
pranav baraskar
NagendraSomaset
Hi Pranav - Were you able to automate this virtual app? We don't want to use surface area automation as the steps are complex.
with v7 they they say they have Citrix support but doesn't seem to support streaming Apps.
Nagendra Somasetty
RPA Architect
AIG
America/Chicago
Hi Nagendra /Pranav,
I am waiting for an updated V7 for Citrix automation to accomplish thru Citrix Automation VDE in my org . Because its very tedious for surface automation to work on citrix on lower version which has higher error margin if its screen is not stable.
For your reference on Citrix Automation using V7
Citrix Automation Setup
BP Docs Blue Prism - Citrix VDE installation
Shikhar Mishra
RPA Lead
Infosys Pvt Ltd
Pune,India
Shikhar Mishra RPA Lead Infosys
