16-08-21 05:05 PM
Srihari
17-08-21 05:47 AM
Looks like there might be some tuning required for the image and the fields you've spied using Region mode.
Just as best practice, it is advised to always use a CheckExists stage before Read actions for BluePrism to ensure that it can interact with those elements.
If it errors out on that stage that's a sure indication that you might need to tweak the region settings for those elements.
Harpreet Kaur Product Consultant
17-08-21 05:47 AM
18-08-21 09:17 PM
Are you using Image based or coordinate based approach to read the values using Region mode?
Consultant
EY
Gurgaon
19-08-21 05:12 AM
I am using Image based approach to read values, the target element is a image which contains tabular data.
Srihari
19-09-21 02:29 PM
Hello Srihari,
Is the application any web based or some windows application?
Why I am asking is if Web based then why not find some way to get the table into the collection directly in navigate stage?
If it is an windows application why not see if some steps might let you export the data into some flat file ?
Region mode has a very high failure rate and should be used as last option.
That too you are using image based recognition rather than co-ordinates so in DEV it might work but in higher environment it might be really a pain.
Best Regards,
Ved Sengupta
Deloitte India (Offices of the US)
Bangalore | INDIA
