Hi Travis Smith
It looks like you are referring about screen distorting in Blue Prism UI?( The screenshot shared was blanck)
if it is UI related try below steps
You can change the compatibility settings of the blue prism. Follow the below steps for Windows 10 users.
1. Go to shortcut of Blueprism
2. Right click > Properties
3. Select Compatibility tab and check Override high DPI scaling behavior. Select system in the drop down.
4. Click on Apply and Ok.
5. Relaunch your Blueprism through the shortcut
Regarding your other questions I would suggest to check Utility collection Actions to manipulate the data .
UI related Issue - Probably the screen resolution or browser settings need to be adjusted
Harish Mogulluri
Lead developer
America/New_York TX
Original Message:
Sent: 11-20-2023 17:47
Subject: A few foundations questions
Hello all,
I have several questions I was trying to get resolved as I am going through this last project for the "foundations" part of learning blue prism. One issue is that I don't see anywhere to change the settings but the height is never correct for the rows on certain menus and screens like the error screen so it cuts off part of the text, and while still attainable it is annoying and I would like to fix it.
<o:p></o:p>
Another issue I was trying to resolve is setting the different parts of a collection so that the data can be separated into it's own category. For instance, in this case after I have taken a collection of rows from a csv, I have it parse through so it grabs one row which has 5 different columns. I want to designate the data from each of those columns to it's corresponding data item so I can then set those values when it goes to create the order and am not sure how to do that.
Finally, another thing that is strange with the application modeler. At times I will map things so that they correspond correctly and do not see any issues, it still works, but when I "highlight" the box it shows an outline of some non existent area. But it is still mapped properly, and it just seems strange.<o:p></o:p>
Any help would be greatly appreciated!
Travis
Travis Smith
