Blue Prism Product
 View Only
last person joined: yesterday
This community covers the core Blue Prism product.
  • 1.  Surface Automation issue
    Posted 9 days ago
    Hi All,
    I have to develop a new process using surface automation in my organization and i am pretty new to it. I tried automating one of the application behind citrix layer and it is failing continuously. Can someone please help in this?
    Rishabh Chauhan
  • 2.  RE: Surface Automation issue
    Posted 9 days ago
    Hi @Rishabh Chauhan,
    What error you are getting while performing the automation?
    Manpreet Kaur
    Manager
    Deloitte
  • 3.  RE: Surface Automation issue
    Posted 7 days ago
    Thanks @Manpreet Kaur for the response.
    I am getting below error:
    Can you please help me in that​
    Rishabh Chauhan
  • 4.  RE: Surface Automation issue
    Posted 4 days ago
    Thanks for sharing the error details. Are you using "fixed" image pattern while creating a region ?​
    Manpreet Kaur
    Manager
    Deloitte
  • 5.  RE: Surface Automation issue
    Posted 2 days ago
    Hi @Manpreet Kaur,
    Are you referring to the position as "Fixed" ?
    Yes, I was using the fixed position for spying the element since the screen resolution is fixed​​​
    Rishabh Chauhan
  • 6.  RE: Surface Automation issue
    Best Answer
    Posted 2 days ago
    Yes, I was referring to the position as "Fixed". Did you try using the position as "Anywhere" or "Relative" as compared to "Fixed" ?
    I understand that the screen resolution is fixed but the zoom percentage, colors of the application, location etc. everything matters while working with Surface automation and in order to make it a stable solution, always try different backup approaches with retry logics.
    Manpreet Kaur
    Manager
    Deloitte
    *If you find this post helpful mark it as Best Answer
  • 7.  RE: Surface Automation issue
    Posted 2 days ago
    Also, please try changing the "Color Tolerance" value as well in order to accommodate different color values.
    Manpreet Kaur
    Manager
    Deloitte
  • 8.  RE: Surface Automation issue
    Posted 2 days ago
    Thanks @Manpreet Kaur for the quick responses. Appreciate your help in this.
    I will check on your suggestions ​​and modify the code accordingly. Thanks
    Rishabh Chauhan
  • 9.  RE: Surface Automation issue
    Posted 2 days ago
    Hey Rishabh,
    It is difficult for any RPA product to get UIs through something like Citrix or an RDP.  It looks like Blue Prism has attempted to solve this with the following:
    https://bpdocs.blueprism.com/bp-7-0/en-us/Guides/citrix-integration/citrix-introduction.htm?Highlight=Citrix
    It is important to note that if you cannot get the Citrix integration to work, you are typically limited to hotkeys and image based recognition.
    Best of luck!
    Michael Annis
  • 10.  RE: Surface Automation issue
    Posted 2 days ago
    HI @Michael Annis,
    Yes, BP v7 tried resolving the citrix automation issue but it requires Blue prism to get installed on Citrix VDE which was not possible in our scenario as client IT department​ denied for the same.
    Rishabh Chauhan
Welcome to the Blue Prism Product Community!
Whether you’re looking to manage a complex infrastructure, maintain security and compliance, bring new products to market faster, or gain operational speed and agility in an uncertain economy, Blue Prism delivers — with the flexibility you need to create the business you want. From deployment on-premise, through a cloud service provider or as SaaS, to a skillful and adaptable digital workforce that continually expands to meet your enterprise needs, you can gain enhanced operational insight and control while your people reclaim the time they need to focus on great work.
Product PageKnowledge BaseBlue Prism Training Offering
Product Research ProgramUpdates, Releases & Announcements
FAQs
Blue Prism is intelligent automation — business-developed, no-code automation that pushes the boundaries of robotic process automation (RPA) to deliver value across any business process in a connected enterprise.
A combination of RPA with expanded cognitive and AI capabilities, Blue Prism is different than other automation technology on the market. With one Blue Prism license, you gain instant access to an already AI equipped digital workforce, along with the tools you need to build and delegate automations. Click here for more information on Blue Prism and Intelligent Automation.
To learn more about how Blue Prism can help your organization and how much it will cost to get started, please Contact our Sales department.
Blue Prism can be downloaded from our customer portal. If you would like to consume or download any material it is necessary to create an account on the Portal. Once you have registered, you can access the download options for Blue Prism here.
Yes! Installed on your own machine and supported by our training materials and product documentation, you can use all the features of the full enterprise product for free with our Blue Prism Trial – giving you the opportunity to learn the basics before moving to a full production implementation. Click here for more information and to download the trial.
Yes! You can access our known issue list for Blue Prism from our Support Portal.
Regardless of your industry, Blue Prism’s Digital Workforce can adhere to strict governance and compliance standards without limiting productivity. Click here for more information on how your industry can benefit from Blue Prism.
