May 13, 2022
Urgent Notification: Use of Chrome and Edge browsers as part of Blue Prism automations
CharlotteK
Community Team (Retired)
Announcement from: 5-13-2022
Google (Chrome) and Microsoft (Edge) have announced that they are changing the way third-party browser extensions are supported. On January 1, 2023, any browser extension that uses their Manifest V2 (MV2) standard will no longer operate.
In response to this announcement, Blue Prism has created a new browser extension that supports Manifest V3 (MV3).
Customers who currently use either of these browsers as part of their automations must upgrade to a version of Blue Prism software that offers MV3 support by the end of 2022 and test their automations as part of that upgrade process.
In addition, customers should be aware that with MV3, Google (and Microsoft) have removed the capability to perform JavaScript invocation or injection. Customers who utilize that capability must modify their automations to overcome the vendor-imposed restrictions.
To help our community of users identify if they are impacted by this announcement - our product team has provided a utility that will determine if you are affected by this issue. We recommend that you run this utility, which can be found here https://digitalexchange.blueprism.com/dx/entry/3439/solution/manifest-v3-impact-assessment-utility
If the utility identifies you are affected (i.e., Using Chrome or Edge / utilizing the JavaScript insert/invoke function) please make sure your organization completes the survey sent to them by their account or customer success manager.
Note: this survey is intended for end-users of Blue Prism only. If you haven't received this survey and feel that you should have, please contact your Blue Prism representative. Information for Blue Prism partners is available on the Connect Partner Portal.
Our upcoming releases (7.1 and 6.10.5) will contain Browser Extension support for Manifest V3.
[Note: these versions will also support those customers who could not apply the January 2022 Microsoft security patch update. Visit FAQs. http://portal.blueprism.com/customer-support/support-center#/path/-Featured-Articles/1784860762/-Solution-Windows-updates-from-11th-January-2022-causing-authentication-issues-in-Blue-Prism.htm]
Our communication regarding this event will evolve in the coming weeks and months. In the meanwhile, please find the latest information in our Knowledge Base FAQs. https://portal.blueprism.com/customer-support/support-center#/path/Alerts/1831250872/URGENT-NOTIFICATION-RELATED-TO-USE-OF-CHROME-AND-EDGE-BROWSERS-AS-PART-OF-BLUE-PRISM-AUTOMATIONS-ACTION-REQUIRED.ht...
5 Comments
Miguel_JesusFer
HI,
Was MV3 included in the latest v7.1 release?
The release notes are not very clear about it
Miguel
Miguel Jesus Fernandez Lopez
Director of Intelligent Automation
INVOKEinc
Hi, Miguel,
As far as I understood, the BP 7.1 is supporting both versions of Manifestos - MV2 and MV3 in general. But the key here is that when Microsoft publishes an update in the Edge (around 2023/01 preliminary), the MV2 won't be supported by browser, which result in stopping automation where JavaScript invokes and injects are used.
@CharlotteK - Is that correct?​
Lukas Ramasauskas
RPA Software Engineer
Swedbank AB
Europe/Vilnius
chris.strong
Hello Miguel Jesus Fernandez Lopez
Yes – Manifest V3 (MV3) extensions for Google Chrome and Microsoft Edge were included alongside Blue Prism 7.1.
Kind regards
Chris Strong
Blue Prism Product Manager
Chris Strong
Product Manager
chris.strong
Hello @LukasRamasauskas
Blue Prism 7.1 only provides support for Manifest V3 (MV3) for Google Chrome and Microsoft Edge and does not also include a compatible MV2 extensions (for Chrome and Edge).
It's the use of MV3 extensions that prevents JavaScript, not a date.
I.e. Use Blue Prism 7.1 with MV3 extension today = no use of JavaScript invoke / insert.
Tip: We're continuing to add to the Knowledge Base FAQs as we get new questions and learn new things.
​Kind regards
Chris Strong
Chris Strong
Product Manager
RafaelRomero
Hello, it's been sometime since I checked on this but has an MV3 extension been released for Blue Prism version 7.0.1 ?  If not, is there an estimated release date?
Thanks!
Rafael Romero
