Application modeller conversion tool not working properly for Blue Prism version 6.10
Shwetavd
Hi Team,
As IE is migrating into Edge, we need to convert the objects from IE to Edge to work fine and for this I am using "Apllication Modeller Conversion Tool".
After the object is converted into Edge, I noted that:
Elements which were spied in HTML mode (in IE) are highlighting fine in Edge.
But elements which were spied in UI mode are not getting highlighted at all. I need to respy them again.
Please suggest if any additional actions needs to be taken for UI elements to highlight in Edge as well.
Shweta
Please let me know the way I can use to make it work.
Shweta
ewilson
Hi @Shwetavd,
There's a new conversion tool available on the DX specifically targeted at IE conversions. It's called the IE Mode Conversion Assistant. It's the same concept as the Application Modeler Conversion utility, but specifically made for the IE use case. It's also been simplified a bit. I'd suggest giving it a try and see if you still have those problems.
