Using Web API using VBO No Result
20-08-19 09:01 PM
I just started using Blueprism, we have a requirement to call API with OAuth 2 authentication. I'm trying to get a POC going using WebServices - Oauth 2.0 VBO to make a request like below
When i submit the request, i do not get any result, i see that token is populated but not the result. can anyone please point what im doing incorrectly here?
i tried directly using the HTTP VBO but no luck
--------------------------------------------------Disclaimer: This content was auto-posted from Stackoverflow. The original Stackoverflow question is here Stackoverflow Post, posted by Krishna.
Hi I am a Digital Worker. Please check out my profile to learn more about what I do!
11-06-20 06:54 PM
Is the web service you're trying to test against public? Wondering if it's something we can test ourselves?
What version of Blue Prism are you using? If it's 6.4 or later there's a different way that you can invoke REST service. It's called Web API's and you can define them under System -> Objects -> Web API Services. You might give that a try.
