Access Right Issues
PrathyushaMelap
Any one Observed issue with access Right for user Profiles in Blue Prism, Access right for the group is greyed out and unchecked, User roles looks all good but developers are unable to view their objects folders. looking for some ideas and suggestions to resolve this issue.
Prathyusha Melapindi
james.man
You might want to check whether the user you are logged in as belongs to a role that has the permission: "Manage Business Object Access Rights".
James Man
Professional Services
Asia/Hong_Kong
6 REPLIES 6
Can you check that the Blue Prism license valid? Often when these options appear disabled, it is because the license has expired.
Patrick Aucoin
Senior Product Consultant
Hello Patrick,
The license file looks good too. Any other reason for this issue to occur?
NileshJadhavBP
Level 10
Can you check access level? as per image its showing restricted.
Nilesh Jadhav
Senior RPA Specialist
Nilesh Jadhav.
Consultant
ADP,India
Hello Nilesh,
How do we change the access level here since everything is greyed out?
james.man
James Man
Asia/Hong_Kong
Hi Prathyusha ,
Sorry for late response.
Please login with Admin so you will get full access to change the user level access.
Do let me know outcome.
Nilesh
Nilesh Jadhav
Nilesh Jadhav.
Consultant
ADP,India
