Hi All,
I am looking for option where I can put some arbitrary wait time between 2 task in given scheduler, like between Restart task and Login task etc.
I have tried below option, appreciate your help if we have any better options?
1. Check is Loggedin? and sleep for some time before it proceeds retry 3 times.
2. Check is Locked? and sleep for some time before it proceeds retry 3 times.
3. Sleep using any other RTR and run subsequent task but can't control provided RTR is available at any given time.
Kindly advise.
Thanks and Regards,
Syed Raza
