BP Desktop and API Installation issues
amaciejasz
I have BP HUB that is working in sandbox environment but have problem to make BP Desktop work.
When I login to BP desktop using BP HUB credentials there is an error "%HeadContent". It could be related to BP API, as BP API is installed but I'm not sure how to easy check if it's work.
Adam Maciejasz
RPA Specialist
RPAi
Europe/Warsaw
Hello, Adam,
did you enable swagger as described in documentation for BPAPI? Then you can build a Postman/SOAPUI call and test your BP API.
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
