BP Process Exposure against VM (resource) pools
Hello, community,
Has anyone deployed a solution where Blue Prism process is exposed as Web-Service against Resource Pool but not a single exact resource?
BP 7.1.1 in use with full on-prem deployment.
Chorus, Hub, API etc. solutions do not fit to current architectural setup and can't be used, thus solution in scope should be designed in BP on-prem only.
Lukas Ramasauskas
RPA Software Engineer / Robotic Solutions Architect
Swedbank AB
Europe/Vilnius
steven.boggs
Hi Lukas,
To run an exposed Process against a Resource Pool, you just have to direct the request to the designated Pool Controller -- we have a Knowledge Base article about how to do this here: https://support.blueprism.com/en/support/solutions/articles/7000078336-how-can-i-run-a-process-which-has-been-exposed-as-a-web-service-against-a-resource-pool-
Steve Boggs
Austin, TX
steven.boggs
Hi Lukas,
Steve Boggs
Austin, TX
