Hi Hassan,
Thanks for your reply. Sending the 'down' key is working for me, but what I am most concerned about is actually finding a way of deciding when the end of the list has been reached. Do you have any suggestions here?
My own thoughts have been:
1. List has ended once the same task appears twice (compare with previous value)
BUT I cannot use this option, as this is not a guarantee that we are at the end of the list... Sometimes, an identical task will appear twice in the list.
Would appreciate input on this.
Br,
Maria
