Blue Prism 24 Hour Challenges - Automation Reviewer
LorenaSeco_de_H
Community Team (Retired)
Hi everyone! 👋
We are launching '24 hour challenges' which are designed for global teams to virtually get together and design the best process possible using Blue Prism.
There will be 4 different challenges in the coming 12 months. You can register your interest for any of them as they are launched on the Community. Each challenge, is designed to test your understanding of Blue Prism development best practices while pushing your technical ability with Blue Prism to the limits. The process your team submits needs to be a useful tool, it needs to work really well and also needs to have a bit of flare!
Our first challenge, Automation Reviewer, kicks off on November 10th and is open for 10 teams of five people.
You and your team, will need a good level of understanding of Blue Prism development and of XML manipulation to build a great process in this challenge and you will be scored based on how you stick to best practices, the performance of your process and design quality. The winners will be selected by a Blue Prism judging panel and will be awarded a Blue Prism goodie bag.
Find all the info and register your interest for the Automation Reviewer Challenge via the RSVP on this event.
We look forward to having you take part in one of our challenges!
Lorena Seco de Herrera Ortega
Community Associate
NileshJadhavBP
Level 10
Thanks Lorena for sharing opportunity with us 🙂
Nilesh Jadhav
Senior RPA Specialist
Nilesh Jadhav.
Consultant
ADP,India
