Hi Jason,
There is a community called
Job Board which is probably what you're seeking....
It notes.....Do you have a Blue Prism related job opportunities? Or are you looking for a career development opportunity? Why not share here 🙂Looks like you'll be the first poster, but there are plenty of subscribers so you may well hit lucky.
If you have experienced BP developers the steps required to become a certified Solution Designer can be found on the University - Portal>University>Certification
here, with Preparation section of the document highlighting the necessary information available via the Portal>Documents. This will provide them with the core knowledge required to become a BP Solution Designer and will ensure your automations are designed, built and architectured in a secure, scalable manner adhering to our industry leading best practices.
Hope this helps.
Kind regards
Andrew
Andrew Beard
Senior Consultant
Australia/Melbourne
