Hi Alves,
Question, have you disabled the "Start a personal Runtime...." setting? I have noticed that this problem occurs when you try to use the port at the same time as the RR.
If you use the application modeller to succesfully spy objects and run the process "step by step", and then start the process from the control room.... the bot wont find some elements.
On the other hand, if you first start the process from control room and run it successfully, and then you try to spy some objects it will fail.
As mentioned in some other posts, closing BP and RR will solve this.
Quick mid term solution?, keep this in mind always, and make sure that the port is available for BP o RR when you need it.
PD: If you cant disable this feature because of permissions, then when you start BP try to close the RR before you do anything else.
Conrado Meli
Managing Partner
Primus IA
America/Santiago
