Business object not working when call from process studio.
BhawanaDaultani
Hi Folks,
I am new with Blue prism tool so facing few issues with the tool.
Trying to call business object from the process studio. Individually object is working(Launching web application , check for element exist and handles error). When I am calling this business object through process studio then it's simply launch the web application and moving to other steps of the process studio. not going to check element in wait stage and others.
I tried to put wait, breakpoints but no success.
Please suggest me what to do in this case. Attaching the screenshot of process and business studio.
Thanks.
Bhawana Daultani
GopalBhaire
Level 10
Hi Bhawana,
You need to step in to (by F11) the action from the process for the breakpoint to get triggered.
Alternatively, you can remove the resume and use an exception stage with preserve checked to see if the action is throwing any error.
Gopal Bhaire
Analyst
Accenture
Thanks Gopal for your help.
It worked. I found the issue  through F11.
Application was not connected.
Bhawana Daultani
