Hi Ge,
Have you tried using send key option rather than write stage, to send the value to the window? If you have not used send key option, it may be worth to try on the option. A suggestion is to spy the Window and file name in Win32 or AA. Activate window using the Window element in a navigate stage and do arbitrary wait, set the time out to be 0.5 s to ensure Window is fully activated. You can then use Global Send Keys, final step is to pass the value to the file name & press Save button.
Second suggestion is to you to spy the button using the Browser spy mode if it is javascript code behind the scene.  Insert JS functions and invoke those JS functions from within a Navigate stage.  Then wrap your "button click" into a JS function, Insert it and then Invoke it.
http://portal.blueprism.com/customer-support/support-center#/path/1140187692Hope this is helpful to solve your problem.
In Joe
In Joe Khor
Sr. Product Consultant
	In Joe Khor
