Button Click Using JAVA Script
23-03-20 05:50 AM
Hi All,
Is anyone has used JavaScript for Button click event?
I have tried with Global send Hotkeys "ENTER" but not working and the PopUp is unable to SPY using BluePrism.
Anyone knows other solution for this ,Please let me know.
Thanks in Advance.
Mohini Shelke
vElement It
Thanks in Advance.
Mohini Shelke
vElement It
25-03-20 02:05 AM
If it is a PopUp window from a browser, it probably can't be interacted with using JavaScript.
If it's something like a "Save As" window, it may be possible to spy is using Win32 mode. The PopUp window may also be in a separate Windows process, meaning that you may need to create a new Business Object and Attach to it separately from the main Business Object. Blue Prism has a Support Centre article that outlines the approach in more detail:
http://portal.blueprism.com/customer-support/support-center#/path/1161378212
But to answer your question, in order to trigger JavaScript, you need to have spied an element using the Browser spy mode. You can insert JS functions and invoke those JS functions from within a Navigate stage. So you could wrap your "button click" into a JS function, Insert it and then Invoke it.
http://portal.blueprism.com/customer-support/support-center#/path/1140187692
James Man
Professional Services
Asia/Hong_Kong
James Man
Asia/Hong_Kong
